Giriş
Microsoldering technique for replacing a faulty IC to restore touch functionality in the iPhone 6.
Neye ihtiyacın var
In this tutorial you will learn how to resolve hardware touch issue in an iPhone 6 smartphone. In case of any troubles contac me through the comments.
12 farklı kişi bu kılavuzu tamamladı.
8 Yorum
Do you change that ic with new one?
thanks before
No, I have desoldered the proper chip from the other motherboard. Thanks for your interest and best luck with the repair!
Is it a good idea to change the whole screen
You are right, but sometimes it won’t work. Especially when it is a hardware issue.
? the logic board is not attached to the screen ... it has nothing to do with the screen, it is that - processor where one of the soldering points is not making contact and the tutorial shows just reheating to the point the soldering melts again and the crack or whatever that makes the connexion is broken gets fixed again, right?
