Öğrenci Katkılı Viki
Bu vikiyi, eğitim programımızdan harika bir öğrenci ekibi yaptı.
Truck makes noise when going over a bump
Despite how slow you go over speed bumps or pot holes the truck makes a loud banging pop.
Check the components of the steering linkage
Look underneath the front of the vehicle between the front tires at the components of the steering linkage. If any of the parts seem to be fitting loose then replace that component. Pay special attention to the idler arm, bolted onto the frame of the passenger side, as it is the most likely suspect. If one of the joints on it is separated or not connected then it is the problem and should be replaced or repaired
Drifting while the truck is in motion
While driving, you experience the truck to be drifting while you hold the wheel steady. It can either be dramatically drifting or barely noticeable.
Visually check the idler arm
Look underneath the vehicle between the front two tires and bolted onto the frame should be the idler arm. If the joints are loose, disconnected or leaking grease then it is time to repair or replace the idler arm.
Mechanically inspect the idler arm on the ground
With the truck parked, have a helper turn the steering wheel while you observe the tires. If he/she can turn the wheel without any resistance and no tires moving then it is time to repair or replace the idler arm.
Mechanically inspect the idler arm in the air
With the front of the truck properly jacked, using wheel chocks and jack stands, try to move the wheels. If the wheels can move without a helper observing the steering wheel turning, then it is time to repair or replace the idler arm.
Cap will not come off the idler arm
When trying to replace the idler arm, it can often be hard to get the cap off so that the joint can be replaced.
Clean all the grease and dirt off the cap
Often times, a good cleaning can make the cap come off much easier. Spray the cap liberally with a grease penetrating agent such as WD-40 or PB Blaster and let it soak for 2 minutes. Once the penetrant soaks into the grease take a rag and wipe the old grease and dirt off. If it all doesn't come off then gently brush it with a steel brush to loosen it and wipe off the grease. The cap should be easier to take off now.
Tap the cap
Insert the arm into a vice and tap the cap with a hard rubber mallet or very gently with a hammer until the cap loosens enough to take off.
Twist the cap
With the arm in a vice, take a large pair of vice grips or channel locks and fit them about the cap. Use the tools to try and get the cap to wiggle, breaking the seal holding it on. Once the cap has some free play in it, follow the instructions on this guide.
2 Yorum
HELP: Need 12v 8w map light bulb for 1989 Toyota 4Runner, before 3/89 model
Manuel Silva - Yanıt
89 4RUNNER 3.0 bad fuel mileage strain to run down the road like it’s getting too much fuel.
Catalytic converter good
air filter good
put new throttle position sensor on
no vacuum leaks
Any suggestions? Contemplating mass air flow sensor.
Brad - Yanıt
