Öğrenci Katkılı Viki
Bu vikiyi, eğitim programımızdan harika bir öğrenci ekibi yaptı.
Weak Vacuum Suction
You have trouble with your vacuum having strong suction to pick up debris.
Suction Tube is clogged
Accumulation of Debris caught in suction tube.
[<iframe src="https://www.ifixit.com/Guide/embed/11420... width="800" height="584" allowfullscreen frameborder="0"></iframe>|Black and Decker CHV1410 DustBuster suction tube disassembly]
Filter is clogged
Visible cracks in filter. Large amounts of debris in filter.
"Link for the removing and cleaning of filter"
Bad Motor
If vacuum is on and all other problems have been eliminated, consider replacing the motor.
"Link for Motor replacement"
Vacuum Not Powering On
" Vacuum will not power on after charging: check connectors, clean and reconnect. If problem persists check battery, power switch, charging port, charger."
Power Switch
When powering the vacuum on/off, you should hear an audible click. If no audible click is heard see “Link” for replacement.
Bad Battery
Short usage time after fully charging.
"Link for replacement"
Broken Charging Port
When placed on charge, a red light will indicate the vacuum is charging. If no light is visible see “Link” for replacement.
Bad Charger
Before replacing charger, verify all other components are in good working order. If wires are broken or power supply is hot to the touch, consider replacing charger.
24 Yorum
when I start my B&D dustbuster it runs for a second and the stops; emitting 2 beeps. What does this mean?. I can’t find a webpage with the error codes.
cmeneely - Yanıt
Vacuum is fully charged but only runs a few seconds and stops. I bought new filters, but it hasn’t helped. What should I do next?
Linda -
how do I find link for bad battery
Lona Gharst - Yanıt
How do I know what motor is needed for my B&D VACUUM. SUCTION is not what it used to be. Under a year of use . Can I return for a new one? It was a Christmas gift.
cilscolors - Yanıt
How do I know what motor is needed? Gift last Christmas so not a year old and suction has significantly decreased. Can I return for another?
cilscolors - Yanıt
