Öğrenci Katkılı Viki
Bu vikiyi, eğitim programımızdan harika bir öğrenci ekibi yaptı.
Camera will not turn on
Pressing the power button does not power on the camera.
Drained / bad battery
The most common cause of a blank screen is an uncharged or expired battery. First, plug your camera into a power source to determine if the battery is simply dead. If this does not fix the problem, it may be necessary to replace the battery with a new one.
Extreme temperatures
The camera should only be charged between 40°F and 90°F. Attempting to charge the battery in extreme temperatures can impair the ability of the battery to take a charge.
Broken charging port
The battery may not receive a charge when you plug it into a power source. This could be the result of a broken charging port.
Screen will not turn on
When the camera is powered, no picture appears on the screen.
Faulty screen connection
If your battery is charged and the camera is powered, a blank screen could result from poor or faulty connection between the camera and the screen. The camera may need to be disassembled and the connections between the camera and screen checked.
Faulty screen
If the camera is powered and the connection between the camera and screen is functional, the screen on your camera may be faulty and require replacement.
No audio / poor audio quality
The built in audio is of a poor quality or non existent.
Occluded speaker
Check the slot at the top of the camera for blockages or debris that could be distorting or blocking sound.
Faulty microphone
Listen to recorded footage on your computer to make sure the microphone is recording sound. This will determine whether the issue is with your speaker or microphone.
Faulty speaker
If the videos recorded with your camera play audio when viewed on your computer, the audio issues are caused by your speaker and it will need to be replaced.
Tripod will not screw into camera securely
Tripod will not securely attach to camera.
Stripped tripod attachment threads
The threads on the bottom of the camera used to attach a tripod are made of plastic and are commonly stripped after repeated use and over tightening. If a tripod will not securely screw into your camera, the threads will need to be replaced.
Unresponsive buttons
The buttons on the camera do not function properly.
Stuck buttons
Debris may be stuck underneath the buttons on your camera causing them to be stuck in the down position. It may be necessary to disassemble your camera to clear any foreign objects.
Damaged buttons
The buttons on your camera may be damaged and in need or replacement.
2 Yorum
Any solutions for these problems?
James Lawrie - Yanıt
My canon vixia r400 does not turn on and seems the bathery is full, when I plug directly does not appear red light too.please help me.
Maritza - Yanıt
