DYMO® LetraTag®
DYMO® LetraTag® etiket makineleri ev veya ofis kullanımı için tasarlanmıştır. El tipi LetraTag® 200B, LetraTag® 100H, LetraTag® 100T ve LetraTag® 100H Plus modellerini keşfedin
Son 24 Saat: 2
Son 7 gün: 20
Son 30 gün: 87
Her zaman: 896
2 Yorum
Please advice, I disassembled the machine, and found a loose spring. I found out that the spring is used to retract the cutter after cutting. But I can't figure out the correct placement of the spring. Does anyone know? It is the handheld version.
Lemonoius - Yanıt Paylaş
Now I know. Disassemble completely the cutter handle and remove the white part. Then remove the circuit board part from the tape holder. Then the cutter mechanism will come out, and the spring belongs inside the part the blade is fastened to. Use this video to disassemble. https://www.youtube.com/watch?v=UoRt52zM...
