Öğrenci Katkılı Viki
Bu vikiyi, eğitim programımızdan harika bir öğrenci ekibi yaptı.
Keyboard sticks
Keyboard keys do not depress after being pressed
Debris under keys
If debris is stuck underneath your keyboard, it may cause the keys to stick when they are pressed. Removing this debris may fix the problem. If you see debris present under the keys, you can use compressed air to blow the debris out from under the keys. You may also try using a toothpick or paperclip to dig it out, or remove individual keys in order to clean underneath them.
Faulty keyboard
If problems with the keyboard persist after cleaning, the keyboard itself may be faulty. In this case, replacing the keyboard may be required.[link]
Short battery life
The battery drains quickly when unplugged from the charger
Improper settings
You may be able to adjust battery settings through Windows Settings to increase the battery life of your laptop. Some presets should be available, as well as a battery saving mode. Some of these presets can be adjusted further as well, and startup programs can be disabled through Task Manager to improve battery life. If battery life continues to be problematic after changing these settings consider replacing your battery.
Faulty battery
If other solutions don’t fix the problem, consider replacing your battery. Remove the faulty battery and replace it with a new battery.[link]
Delay on touch pad
After moving a finger across the touch pad, there is noticeable delay before the cursor moves
Improper Settings
Delayed responses from the touchpad may be caused by improper settings. To adjust these settings perform the following steps:
- Open the Synaptic Point Device Properties.
- Click the Device Settings tab and then select the Settings box.
- Expand the Pointing menu and then expand the Sensitivity menu.
- Select Touch Sensitivity and slide the sensitivity meter from "2" to "1."
- Press OK.
Faulty Touchpad
A broken or defective touchpad may be the cause of the delayed response, so replacing the touchpad may be necessary.[link]
Slow performance
Programs run slowly on the laptop
Too many programs running
You may have an excessive number of programs running on your computer. Consider using Windows Task Manager to see which programs are using large amounts of computer resources. Once you’ve identified programs that are using large amounts of resources, use Add Or Remove Programs to uninstall those programs.
Not enough/faulty RAM
Faulty or insufficient RAM may cause programs to perform poorly on your computer. Consider replacing or adding more RAM.[link]
Excess files
Your hard drive may simply be too full to perform optimally. Consider removing old or unimportant files from your system to free up space. Navigating through Settings to System and then Storage will allow you to see many options available through Windows to manage storage space. If the problem persists you may need to replace your hard drive.
Faulty hard drive
If other solutions have not yielded results, consider replacing the hard drive.[link]
Hard drive failure
Files are corrupted, take a long time to open or there is a bootup warning about the condition of the hard drive.
Excess files
Faulty hard drive
0 Yorum
