Öğrenci Katkılı Viki
Bu vikiyi, eğitim programımızdan harika bir öğrenci ekibi yaptı.
Honeywell HY 254 TGT Troubleshooting
Model: HY-254-TGT
The fan is not turning on
Not plugged in properly
If the fan does not turn on, ensure the fan is plugged in properly.
Buttons and or remote not in working order
If no noise occurs, ensure both the remote and front panel do not start the fan. If only one does not function, please check the respective repair guide for the remote or front panel buttons. If neither the remote nor the front panel starts the fan, you may need to replace the motor assembly.
Obstructed fan blade
If the fan makes noise but no air moves, look at this guide to open the fan and remove any objects obstructing the fan blade.
The fan is not rotating or is rotating slowly
If the fan is not oscillating properly, the fan blades may have an object obstructing their motion. Follow this guide to remove the fan casing and ensure that nothing is in the way.
Faulty oscillation motor
If the fan is not oscillating properly and there are no objects obstructing it, you may need to replace the oscillation motor.
The front panel buttons do not respond
Stuck buttons
If the front panel buttons are not responding, the buttons are likely stuck, due to dirt that has gotten under them. View this guide to repair stuck buttons.
Broken buttons
The buttons themselves could also be broken. View this guide to repair or replace broken buttons.
The remote does not respond
No clear line of sight between the remote and the fan
Make sure that there is a clear line of sight between the IR blaster and IR receiver.
Batteries not in working order
If the remote does not turn on the fan, ensure the remote has functional batteries. If not, use this guide to replace them.
Faulty remote
If the remote is still not working, it may be faulty. You will have to take the remote apart and replace the circuit board, or just replace the entire remote.
29 Yorum
Hi sir,
No power on the tower fan at all, the buttons on the front of the fan, are not stuck, and the remote control flashes okay. but the fan stopped working.
can you help
Rashad - Yanıt
The tower squeals fan turns and air is moving. What can be done?
Sharon Score - Yanıt
If something squeals that means there are surfaces rubbing against one another. Just listen closely to where the noise originates. Check all your easy-access screws and stuff and be sure everything you can easily reach is in good order.
If that doesn’t change anything then you may have some dust or something in between your fan housing and your center shaft…time to take it apart and clean where they touch.
Usually that’s it. Squeal free.
beauX tschirhart -
Fan started changing it's own settings at random and the only way to turn it off was to unplug it. After a few weeks of this, the fan now runs only on low speed and oscillates. The remote has no effect. The controls in top of the unit have no effect. Plug it in and it's on as described. Only way to turn it off is to unplug it. Seems like a problem on the logic board. Hopefully, I can find a replacement part.
Neil - Yanıt
I'm having the same problem Neil, now my remote works to oscillate & up /down speed but dosnt turn the fan on or off, is there any way to buy a new remote ?
c.stewart10 -
