Öğrenci Katkılı Viki
Bu vikiyi, eğitim programımızdan harika bir öğrenci ekibi yaptı.
Lenovo tablet won't turn on
No matter what you do, you can't get your Lenovo tablet to turn on.
Faulty battery
Before diving into the guts of your tablet, make sure to hold the power button.
Drained/bad battery
If your tablet won't turn on, you may simply have a drained battery.
Bad display
It is possible that it appears nothing is happening because the display is bad. If the screen does not turn on, it is possible the display is bad and must be replaced.
Lenovo tablet won't connect to internet
When I open the browser, the webpage won't load.
Enable WiFi
Check the settings to see if the WiFi is on. If not, click the on/off switch until it is lit up.
Poor connection
Check to see if your tablet is connected to a local network. If you are trying to connect to a private network, make sure you have the proper credentials to access the network.
Testing connection
Open browser and reload the webpage.
Faulty Bluetooth pairing
My Bluetooth speaker won't connect to the Lenovo tablet.
Bluetooth not enabled
Check the settings to see if the Bluetooth is enabled. If not, click the on/off switch until it is lit up.
Scan for Bluetooth devices
After the Bluetooth is enabled, scan for nearby Bluetooth devices. The device automatically searches for available connections.
Tablet won’t pair with other devices
Check to see if both devices are paired to each other. If not, disconnect tablet from any other paired devices.
Media problems
I cannot hear media playing on the tablet.
Tablet volume turned off
Make sure the tablet is not on mute. Raise volume using the volume rocker on the left side of the device.
Headphones are connected
Make sure that the headphones are not connected.
Camera is not working
I cannot take pictures with the tablet.
Camera application not opening
Reinstall device drivers. In order to do this, you must go into settings and click on "Backup and reset" - Factory data reset. Before doing this make sure to save all data on a separate hard drive.
Dead Motherboard
If all else fails, the system board may be dead. The Lenovo TAB 2 A10-70 System Board Replacement guide will be sure to help you out.
Cracked or damaged screen
The camera on this device is built into the front panel, so damaging the screen may cause problems with the camera. For more help with replacing the screen, check out the Lenovo TAB 2 A10-70 LCD Screen Display Replacement Guide.
39 Yorum
i have a problem with me Lenovo Tab2 A10 70F when i turn it goes on but it stays on the first faze of it turning on i do have it rooted but today i got a thing saying there was a root problem
so i turned it off and when i turn it back on it just stayed on the first part
if you want to contact me my E-Mail is elijahshoebridge@gmail.com
elijah shoebridge - Yanıt
My tablet can not turn on or be charged.and it's still new
magadalene iris - Yanıt
Kindly assist,your assistance will be highly appreciated
My Lenovo Tab2 A10-70 won't turn on. Was fine yesterday, picked it up today and it appears dead.... tried charging but no response... any advice?? is this a common problem for the Lenovo tab2 A10-70???
Stephen Sutton - Yanıt
mines doing the same thing. ive been trying to fix it all day. different chargers, constant trick of using paperclip and hold power button. nothing. just did it early this morning. was fine lastnight cause my son was using it. i did notice the charger piece inside the tablet was alil bent managed to make it as straight as possible (with gentleness) i put tablet aside and check it periodically. i think its completely drained cause of my son, but im not sure. if anyone can help...all ears....lol
tiffany -
