Öğrenci Katkılı Viki
Bu vikiyi, eğitim programımızdan harika bir öğrenci ekibi yaptı.
Computer Won't Turn On
Your computer is unresponsive when using the power button.
Computer Charger Is Not Charging The Battery
Your computer may not be turning on due to the charger failing to charge the laptop. To check if the charger is functioning properly, connect the charger to the laptop and multiple power sources. After plugging the charger into each power source, check if the charging light on the laptop turns on. If the charging light turns on, then the charger is functioning properly. However, if the charging light does not turn on from any of the power sources, your charger is not functioning properly and needs to be replaced. Refer to manufactures website to replace your charger.
Computer Battery Not Working
Your computer may not be turning on due to the battery being unable to hold a charge. To check if the battery is malfunctioning, connect the charger to the laptop and a stable power source. Assuming the charger is functional and the charging light comes on, allow the battery to be fully charged. To allow the battery to fully charge, you will need to wait a few hours before proceeding.
After allowing your battery to charge, try pressing the power button to turn on your computer. With your computer on, unplug the charger from the computer. If your computer turns off, either immediately or shortly after unplugging the charger, then the battery needs to be replaced. Refer to manufactures website to replace your battery.
Computer Not Charging
The computer loses power despite being plugged in.
Bad Outlet
Try unplugging and then plugging back in the AC Adapter. If this does not resolve the issue then try a different outlet. It may be that you have a short or blown fuse. If this is not the case then there is a problem with either the Adapter or the battery.
Bad Battery
Your battery may not be working due to the battery being unable to hold a charge. To check if the battery is malfunctioning, connect the charger to the laptop and a stable power source. Assuming the charger is functional and the charging light comes on, allow the battery to be fully charged. To allow the battery to fully charge, you will need to wait a few hours before proceeding.
Faulty AC Adapter
Your AC adapter may not be turning on due to the charger failing to charge the laptop. To check if the charger is functioning properly, connect the charger to the laptop and multiple power sources. After plugging the charger into each power source, check if the charging light on the laptop turns on. If the charging light turns on, then the charger is functioning properly. However, if the charging light does not turn on from any of the power sources, your charger is not functioning properly and needs to be replaced. Refer to manufactures website to replace your charger.
Overheating
If the computer is not charging this could be due to overheating. Turn off the computer for a while so it can cool off and then turn back on to see if the problem is resolved. Clean the air vents and fan ports if they are obstructed by debris.
Keyboard Not Responding
When you push a button on your keyboard it is unresponsive.
Missing/Update Drivers
Your keyboard may be unresponsive due to a missing or an out-of-date driver. To install/update your keyboard driver, turn on your computer and login. Next your going to want to open the application, "Control Panel." To open or find control panel, you can use the windows search bar and enter "control panel" to find it. Once Control Panel is open, use the provided search bar to open "Device Manager". Then Navigate to the "Keyboard" Section, expand the tab, and double click on the desired keyboard. In the new window, select the "Driver" tab, and click the "Update Driver" button to install/update your keyboard driver.
Dirty Keyboard
Your keyboard may be unresponsive due to being dirty. To clean your keyboard, you will want to remove any and all substances logged into your keyboard. To do this use a can of compresses air or aerosol into your keyboard, while the keyboard is facing upside-down.
Mouse Not Responding
When using the touch pad mouse, it does not move the cruiser on screen.
Water Damage
Your touch pad mouse may be unresponsive due to water damage. There may be some water interfering with the touch pad, so you will want to let the water evaporate by letting the device sit for 24 hours. After waiting for 24 hours, all water should be gone and the touch pad should be functional. If the touch pad is not functional, the touch pad will need to be replaced. Refer to manufactures website to replace your touch pad.
Your touch pad mouse may be unresponsive due to a missing or an out-of-date driver. To install/update your keyboard driver, turn on your computer and login. Next your going to want to open the application, "Control Panel." To open or find control panel, you can use the windows search bar and enter "control panel" to find it. Once Control Panel is open, use the provided search bar to open "Device Manager". Then Navigate to the "Mice" Section, expand the tab, and double click on the desired mouse. In the new window, select the "Driver" tab, and click the "Update Driver" button to install/update your mouse driver.
USB Port Not Working
The computer will not recognize devices that are plugged into the USB port.
Dirty USB Port
Wiggle the USB device up and down. If it is loose then the USB port may be damaged. Closely look at the port. Your USB port may be dirty. To clean your USB port, you will want to remove any and all substances trapped in the wide open port. If you see anything, shut down the computer, and then use compressed air or aerosol to knock out any dirt or debris. Turn the computer back on to see if the problem is resolved.
Bad USB Port
Your USB port may be unresponsive due to not working. You will want to ensure the USB port is working by inserting a USB device into a different USB port. If the USB device is recognized by the computer, then the original USB port needs to be replaced. Refer to manufactures website to replace your USB port.
Bir Yorum
List of changes
1. Changed order of issues, previous order was: From keyboard, not turning on, mouse not responding, usb port, not charging
2. Changed summary, to reflect the new order of issues
3. Changed summary, adding the phrase “This troubleshooting guide will cover:”
4. Changed summary: removed “/” characters and replaced with “,”. “/” characters can be interpreted as a symbol for “OR”, when we mean it to mean “AND”
5. Capitalized T in troubleshooting in title
6. Made content changes , labeled as Ricky Edit’s, as to not delete the original
OVERALL OPINION: original content made a lot of assumption and skipped over steps. It was also unclear on certain things, so I changed that.
THINGS TO LOOK AT: The two sections “Computer wont turn on” and “computer battery not working” contain a lot of overlapping content. We may want to reevaluate this as a team
Ricky - Yanıt
