Öğrenci Katkılı Viki
Bu vikiyi, eğitim programımızdan harika bir öğrenci ekibi yaptı.
Screen Malfunction
Did you punch your screen? Be honest...
Screen Punching
If your screen is showing nothing or an explosion of all the colors after an 'accident' your screen is broken. This will necessitate the procurement of a new one.
Loose Wires
If you really didn't punch your screen and it's showing nothing, you have some loose wires. Fortunately, this is as easy as plugging them back in.
Laptop Will Not Turn On
I press the on button, however the laptop won't show any sign of turning on!
Faulty Adapter
Check to make sure the power adapter is plugged in. If it is, make sure the light on the adapter is on. If the light is not on, and the adapter is plugged in, the adapter is faulty. Consider purchasing a replacement adapter.
Laptop Does Not Stay On Unless Plugged In
Faulty Battery
When my laptop is plugged into its charger it functions fine, but when I unplug it from the wall charger, it instantly shuts off.
If the adapter is plugged in, and the light on the adapter is on, make sure the adapter is connect to the laptop. If the laptop only powers up when the adapter is plugged in, regardless of charging time, then the battery is faulty.
Laptop Shuts Down Unexpectedly
While I am using the laptop, the laptop shuts off randomly and without warning.
A computer spontaneously shutting down is never a good thing. This is typically indicative of a cooling problem.
Cooling Problem
Is your laptop hot to the touch? Is it making a loud "whirring" sound?
If the answer to one or both of these questions is yes, you have a cooling problem.
Your computer has built in safeties to prevent damage if your computer gets too hot. In order to prevent said damage it will shut off unexpectedly.
Vent Blockage
Try blowing on your vents which are on the left side of your computer.
Fan Failure
If your laptop is hot to the touch, but makes no "whirring" sound your fan has likely failed.
Not Enough Ram
If your laptop does not feel hot to the touch after running for a while, but still will not boot up, you may not have enough RAM or even broken RAM. Either way, if RAM is the problem it's time for a replacement.
Laptop Does Not Boot
I turn on my laptop, but instead of loading the Windows operating system, it shows me an error message.
Not Enough Ram
If your computer crashes during normal operation, crashes during memory intensive tasks, or beeps and will not boot up, this means you either have bad RAM or not enough RAM.
Hard Drive Error
Even though you have a hard drive in your computer, there may be an error on it. This can happen when the user shuts off the computer by pressing the power button instead of initiating the shutdown sequence through the operating system. To resolve this issue, get a Windows DVD for the version that you have. Please note that the specific version does not matter, only that it is for Windows XP, Vista, 7, or 8. Boot to the DVD, and choose “Repair your computer,” then click next. On this screen, select “Startup Repair” and let it run. After this, your Device should boot correctly. If your computer does not boot correctly and still has issues, your hard drive may need to be replaced.
Laptop Does Not Detect USB Drive
I put my USB Drive into the USB port, but I can't see it anywhere.
Dirty Ports
Your ports may simply be dirty. Try blowing on your USB ports to dislodge any debris and try again.
USB Drive Failure
If blowing on it doesn't work, it's time to disassemble your computer and replace the USB port. Don't worry, this is an easy fix. Or your could go the rest of your life without USB ports. Your choice.
Optical Drive Does Not Work
I want to use a CD in my laptop, but the CD drive does not function properly.
Optical Drive Doesn't Open
This means motor failure. In addition, it means you have to buy another optical drive.
Optical Drive Opens, Does Not Read Disk
This means the laser that reads your disk is dead. Don't worry, it probably went to Heaven. Depending on what you've been looking at. Again, time for a new optical drive.
Laptop Overheats
My laptop gets very hot.
Vent Blockage
Try blowing on your vents, which should be located on the left side of your computer. Alternatively, you can use a can of compressed air to carefully blow the dust off the vents.
Fan Failure
If your laptop is hot to the touch, but makes no "whirring" sound your fan has likely failed. If this is the case, your fan will need to be replaced.
Bir Yorum
np300e5a-a01ae laptop screen blinking
Mahmud - Yanıt
