Öğrenci Katkılı Viki
Bu vikiyi, eğitim programımızdan harika bir öğrenci ekibi yaptı.
Device will not turn on
The Sony TCM-919 won't turn on.
Dead Batteries
If the device will not turn on, it may be the case that the batteries are dead. Simply remove the battery cover by following the guide found here to replace the batteries.
Loose Motherboard Connection
The wires connecting the motherboard of the cassette player may have become loose or broken over time. This will cause connections from the power that the motherboard supplies to be cut off from the rest of the device. Follow the guide here in order to re-solder and replace broken wires.
Bad Motherboard
If the prior solution did not fix the cassette player, it may be a more serious issue: the motherboard is dead. Follow the guide here in order to remove the back cover and check that the motherboard connections are all connected securely. If all connections seem to be secure and no wires are frayed, then the motherboard is dead. Follow the guide here to replace the motherboard fix the device.
Device will not produce sound
There is no sound coming from the Sony TCM-919.
Incorrect Cassette Tape Settings
First ensure that the cassette is placed correctly in the player with the larger part of the cassette being placed closer to the buttons. Next, make sure the volume slider is turned up. Then, watch to see if the tape spins when the play button is pressed. If a faint noise comes out of the speaker it may be that the batteries are dead.
Dead Batteries
If the device will not produce sound, it may be the case that the batteries are dead. Simply remove the battery cover by following the guide found here and replace the batteries.
Broken Speaker
If all else fails then the speaker itself may be broken. Open up the back cover and check the connections from the speaker to the motherboard. If the connections seem frayed or disconnected desolder them and replace them. If this does not solve the problem then remove the speaker and replace it with a new one using the speaker guide here.
Device will not record sound
The Sony TCM-919 is not recording sound.
Insufficient Space Left on the Cassette
Check to ensure that the right hand side of the cassette has less tape than the left hand side. If it has a significantly larger amount of tape than the left hand side, it means there isn’t much room left to record. Simply flip the tape around for more recording space.
Dead Batteries
If the device will not record sound, it may be the case that the batteries are dead. Simply remove the battery cover by following the guide found here and replace the batteries.
Broken Microphone
If all else fails then the microphone is broken. Open up the back cover and check to see if the wires of the microphone are frayed or broken. If so, replace them following the guide here. If this does not work then the microphone is dead. Replace it by following the guide here.
Device Door will not Open or Close
The Sony TCM-919's Cassette Door is Stuck.
The Latch that Holds the Door is Dirty
The latch holding the cassette door may be dirty or blocked up. Simply hold the eject button down and turn the cassette player upside down. Shake the player a bit until the door comes open. Turn it back around and take a good look at the latch found on the right side of the door. If there is any visible gunk or blockage, use tweezers or a cotton swab dipped in cleaning solution to free up the blockage.
The Eject Button is Broken
It may be that the eject button itself is broken. Open up the back cover and locate the eject button found on the inside of the top cover. If the button is not broken it could be the case that the button came detached from the cassette motherboard portion of the player. Follow the guide found here in order to reinsert the buttons into the correct place.
Device Buttons will not Depress
The Sony TCM 919's Buttons are Stuck.
The Buttons are Dirty
If the buttons on the Sony TCM-919 are becoming stuck, there may be some blockage that is preventing them from moving. Lightly spray the surface of the buttons with a cleaning solution so that some of the solution seeps in between the buttons. Try and press the buttons gently until they feel as loose as they should be. Repeat 3-5 times until you feel they are completely clean. If after 5 tries the problem still exists then follow one of the other steps.
The Buttons are Broken
Open up the back cover and look at the top portion of the device. If the buttons appear snapped or broken in anyway, they will need to be replaced. Follow the guide found here in order to replace them.
The Buttons Became Detached from the Motherboard
If all else fails then the buttons may have become detached from the motherboard. Each button has a tab that connects it to the motherboard and pulls a switch in order to performed its designed function. Follow the guide found here in order to place the buttons back into the correct position.
7 Yorum
Mine plays but keeps stopping every 2 seconds like it's at the end of the tape even though it isn't but if i hold it down it plays but it can hear the deck clicking trying to turn off what's wrong
SKINNY00 - Yanıt
Likewise with my Sony unit.Help would be appreciated-I like my old tapes!
cinedux - Yanıt
My recorder plays a high pitch noise while playing back. Audio is still audible and noise stops sometimes if I press the cassette door.
Rafael Puyana - Yanıt
I do not have this particular model, but I am reading all of the posts about tape recorders in hopes that we can figure out the problem with the one we have.
I do not have this particular model, but I am reading all of the posts about tape recorders in hopes that we can figure out the problem with the one we have.When I tried plugging in headphones into the Jack, I could hear it click.
When I tried plugging headphones into the Jack, I could hear it click.I
carrie - Yanıt
I bought a really nice complete Sony TCM-919 to hook up to a ZX Spectrum Computer. I’ve not had a chance to load any games using it, but when I played an audio tape in it the speed of the audio would slow down and speed up. It would not stay constant. I wonder if changing the belts might help?
dlc28 - Yanıt
