Öğrenci Katkılı Viki
Bu vikiyi, eğitim programımızdan harika bir öğrenci ekibi yaptı.
Computer Does Not Power On
"When trying to use the computer... you can't"
Try checking your power cord, and try starting the laptop without a battery installed. Try another power cord to ensure there is no hardware issues with the laptop.
Battery Needs Recharging
Plug power cord into it's proper input and allow some time to pass. If the computer does not power on, the problem might be the cord.
Faulty Power Cord
Try another cord. If the new cord doesn't work it might be due to the input port.
Defective Power Cord Input
If this is the case, the input will need to be replaced by your local computer geek.
Computer Goes Into Sticky Key Settings
"The shift key is hit multiple times so the preferences are changed."
Incorrect Computer Settings
Before calling customer services and spending your day on the phone, make sure to check the settings for the Sticky Key.
Computer Needs to Restart
If going to the settings does not work/help, restart the computer.
The Screen Turns Blue
"The screen turns blue, preventing you from doing anything."
This could be an error with damaged hardware, or just a operating system bug. Try restarting.
Hold the power button until the screen turns black. Unplug if necessary. Wait 2 minutes before turning back on.
Stylus Does Not Work
"The cursor stops moving when the stylus and the screen come in contact."
Dirty Stylus and/or Screen
Using a laptop screen cleaner, wipe the screen and stylus down to make sure there is no residue between them.
Touch Screen is Broken/Damaged
- First, try pushing the stylus moderately harder onto the screen.
- Then, if that does not work, use your finger to touch the screen and move the cursor, checking if the screen is responding.
- Lastly, you can use another stylus, if you have one already, for the current stylus you have may have poor responsiveness.
If any of the above solutions do not work, you need to replace touch screen.
Touch Pad Does Not Respond
"When you try to select/click on the screen, the touch pad does not let you."
Jammed Touch Pad
Remove the touch pad carefully and clean under it thoroughly, making sure that there is not anything preventing you from clicking the mouse.
Dirty Touch Pad
Using a laptop screen cleaner, wipe the screen down to make sure there is no residue. Also, wash and dry your hands for it can affect the touch pad's responsiveness.
Incorrect Control Panel Settings
Using your stylus and touch screen, go to Control Panel > Mouse to check if the touch pad is still connected. If not, connect it.
Computer Frozen
Sometimes the computer freezes so the mouse does not respond. Hold the power button down until the screen turns black. Unplug if necessary. Wait 2 minutes before turning back on.
If this does solve the issue there might be an issue with the ram or cpu.
Finger Print Scanner Does Not Work
"When the scanner does not recognize your finger, giving you an error and not letting you into your computer."
Dirty Finger Print Scanner
Using a laptop screen cleaner, wipe the finger print scanner down as thoroughly as possible to get rid of residue that may be on there. Also, wash and dry your hands.
BIOS (Fingerprint Scanner Software) Needs an Update
Check your Device Manager or Updates Option to see if you need updating. You can also download one online.
Computer Not Responding
Sometimes the computer acts up because it has not been restarted for awhile. Hold down the power button until the screen turns black. Unplug if necessary. Wait 2 minutes before turning back on.
Computer Displays an Error Code
"When the computer turns on, the displays is black but shows a single error code."
Error Code "System Memory Error"
An error has occurred with the computers memory, try uninstalling and then re installing the RAM.
Error Code "Select Bay HDD Error"
An error has occurred with the computers hard drive, try removing the hard drive and placing it back. A replacement drive may be needed.
Hard Drive
The computer will not turn on. The problem with the hard drive could be the boot file, which may be corrupted or damaged. By making contact with any magnetic based device and all data has been lost.
0 Yorum
