Öğrenci Katkılı Viki
Bu vikiyi, eğitim programımızdan harika bir öğrenci ekibi yaptı.
Speaker Won't Turn on
No matter what you do, you can't get your speaker to turn on.
Faulty Power Switch Connection
Check to make sure the power switch is "On" and the power light is on. If the power light is on, then the speakers are on. If power light will not turn on, you may need to replace the wires using this guide.
iHip Fold-up Portable Speaker Replacement
Faulty Battery Connection
Check to make sure the power switch is on, and the power light is on. If the power light does not come on, try to rearrange the batteries so they can properly connect to the battery coils, or you can plug in the device using the DC in auxiliary plug.
iHip Fold-up Portable Speaker Battery Replacement
Stand Doesn't Work
IPod dock wont stand on its own.
Stand is Jammed
In order to use the stand, pull it forward and around the system. If the stand will not pull around the system, consider taking off the back of the speakers and removing the stand using this guide.
iHip Fold-Up Portable Speaker Stand Replacement
Stand is Broken
The stand will pull around the system, but will not stand because the plastic is broken or cracked. Consider removing the stand and then replacing it using this guide.
Drained/bad battery
The speakers won't turn on, but there are batteries inside.
Check to make sure the power switch is "on" if the power light does not also come on, you may need to change the batteries. To change the batteries use this guide.
Faulty Speaker
If no sound is emitted or sound emitted is too quiet, too loud, or fuzzy.
Audio Distortion
Once the iPod is plugged in it should play music audibly. If the music volume is wrong or fuzzy, check to make sure nothing is blocking the device from fully connecting to the dock. If the music still sounds wrong, there may be a problem with the speaker connection wires. Fix the wires using these guides.
iHip Fold-up Portable Speaker iPod/iPhone Input Replacement
iHip Fold-up Portable Speaker DC IN 6V Adapter Replacement
Won't Play Connected Device
Check to make sure the music is playing on your iPod. If the music is playing and no sound is being emitted, there may be a problem with the speakers "line in" wire connection. To fix this problem, use this guide.
6 Yorum
How can i Change the language to English ?
Levi - Yanıt
The Bluetooth headset language from English and can't get back to English
Levi - Yanıt
Change from English to a language I don't understand
Levi - Yanıt
How can I reset it back to English
Levi - Yanıt
Can't remember my passcode
Maurice - Yanıt
