Ana içeriğe geç
Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 Soru Tümünü görüntüle
The touch screen on my iPod touch isn't working after replacement.
I replaced my ipod touch's screen and digitizer because it was cracked. But now the touch screen is not working. It won't let me turn it off, or unlock it or anything touch wise.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
Emily, double check or your work. Make sure that the cables are properly seated and properly connected. If that does not resolve this, it is possible that your digitizer is faulty. Contact the vendor to arrange for an exchange with a working one. Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
Which cables should I check?
tarafından
I most certainly would check the ones from the assembly. Follow this guide to double check your work.
tarafından
Yorum Ekle
Check the connection on the back of the board it is to the digitizer.
Puan 0
1 Yorum:
We are having the same problem. We have tried 3 different screens all with the same result. We have made sure the digitalizer cable is securely connected underneath the board. We are checking to see if there is any reset for the digitalizer like there is for the display.
tarafından
Yorum Ekle
Yanıtını ekle
Emily sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 4,412
