Ana içeriğe geç
Model A1059 or A1099 / 20, 40, or 60 GB hard drive / touch sensitive click wheel
should I replace the logic board?
I am trying to fix my friends iPod 4th Gen 40GB with mono chrome screen. The Symptions are very strange. Firstly the battery is shot (the original battery was manufactured in November 2004) and won't hold a charge. I replaced the battery with a new one from iFixit.com. The iPod now turns on and holds a charge. When i plug it in to a wall charger it charges. If i plug it in to my computer it won't be recognized by Windows nor iTunes. it says that "the device reports that it is malfunctioning." with error 45 and error 10.
Now here is the weird,
If i have the iPod plugged in, the menu freezes. if i push a button, then pull out the charger cable, the action will take place. if i am playing a song, then plug in the charger cable, the song will play for 10 seconds then stop. if i unplug the charger cable, then the song will resume playing and the Menu will respond to button presses. My question is should i replace the Logic Board? I am a techie but i don't want to invest in a $50 logic board for it not to work. I have tried different plugs and chargers.
all help is appreciated
jakthebomb
Bu iyi bir soru mu?
Puan -1
2 Yorum
I'm having similar issues with a 4th gen, I'm going to try and replace the internal hard drive with a cheap compact flash card first, (it requires an adapter which you can easily get on ebay) and see if that fixes mine. You might could do the same?
tarafından
I noticed you never got an answer to this. Are you still having this problem?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
It turned out to be the Logic board. Sorry i didn't close this question.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
jakthebomb sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 1,096
