wifi wont work after replacing battery
Just replaced the battery on my wife's 3GS.
Whats happening:
(1) Wifi won't recognize the network unless you are standing right next to the router.
(2) When wifi is on, the cell bars drop
What Did I check / Try:
(1) Disassembled and reassembled twice more
(2) Verified coax connectors #6 & #7 are undamaged and well seated
(3) Verified copper tabs making solid contact with bezel
The only thing I can suspect is that I probably didn't do a full shutdown before the first replacement attempt
One more bit of info, probably unrelated, but may be a hint to someone. Before I even tried to perform this operation my wife has been reporting a noise from within the device, when turned off! When I have it open I see that the vibrator keep spinning in low speed.
Thanks!
Bu iyi bir soru mu?
