Ana içeriğe geç
Second generation of Wi-Fi iPad, released on March 11, 2011. Model number A1395. Repair is difficult and will require heat.
250 Soru Tümünü görüntüle
Battery removal, torn black outer material - dangerous?
I'm changing the rear, aluminium casing on an iPad 2 which obviously involves prying up the battery from the large amount of adhesive that it's stuck down with.
I did this as carefully as possible, but a small amount of the black material or 'film', that covers the battery was left behind on the old casing adhesive.
This has exposed a small area of the battery (I can see a silver layer underneath) and the battery also now has a 'chemical' or 'solvent' smell to it.
The three cells have also bent very slightly during the removal process (it seems almost impossible to me to get them out perfectly flat)
Is this battery still safe to re-use or do I need to buy a replacement?
If I do need to replace it, is it safe to store inside my house in the mean time or is there any risk of fire/explosion?
Thanks in advance for any advice.
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
4 Cevap
Filtre ölçütü:
Seçilen Çözüm
If it is a strong chemical smell then I would replace it without thinking twice. It's not worth the risk. I have seen damaged batteries reused in ipods and it never turns out well.
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
Time for a new set of cells - Even if the cells are not leaking now you have a hole which the chemicals can leak out and if the metal contacts the case things could also short out.
A time bomb waiting to go off!
Puan 2
2 Yorum:
So then, how should I dispose of a torn battery?
tarafından
Contact your local battery recycler
tarafından
Yorum Ekle
If you can smell it, you need to replace it. We've had an iphone 4s battery explode in our shop. Not something you want to happen ;)
Puan 1
Yorum Ekle
I tore a hole in the fabric and it is tiny. I can see a needle size hole in the fabric when I pried the battery out of the adhesive. No smell or damage to the cells just a minor splinter or damage to the outer skin. Is it still ok to use it?
Puan 0
1 Yorum:
[image|2128922]
This is the battery that has the tare on it.
tarafından
Yorum Ekle
Yanıtını ekle
simon evans sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 13
Son 30 gün: 28
Her zaman: 10,732
