Ana içeriğe geç
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 Soru Tümünü görüntüle
Why internal mic works only when display lid is fully opened?
Internal mic works only when display is almost fully or fully opened. So could it be mic connector on the logic board or the mic cable? Any experience of this fault? If I looked from the guide section correctly there should be a screw securing mic cable to the computer. So is it more likely that the cable is broken? I hope it is a loose connector because it would be easier to fix..
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
I think you've made an accurate diagnosis of the issue. I'd replace the cable, probably Apple part #922-7888. I'd also examine the inverter cables that travel the same hinge while you're at it. I don't know your exact machine but this part will work in the following and can be found for $1.00 with a web search.
Macbook 13.3" 2.0 GHz Intel Core 2 Duo White - Apple Computer MA700LL/A
Macbook 13.3" 2.0 GHz Intel Core 2 Duo Black - Apple Computer MA701LL/A
Macbook 13.3" 1.83 GHz Intel Core 2 Duo White - Apple Computer MA699LL/A
Macbook 13.3" 2.16 GHz Intel Core 2 Duo White - Apple Computer MB062LL/A
Macbook 13.3" 2.16 GHz Intel Core 2 Duo Black - Apple Computer MB063LL/A
Macbook 13.3" 2.0 GHz Intel Core 2 Duo White - Apple Computer MB061LL/A
Bu yanıt yardımcı oldu mu?
Puan 4
2 Yorum:
Thanks! Found for $0.25 from Powebookmedic. :) My machine is late 2006 1.83GHz C2D. There's no guide for microphone replacement so which guide should I follow? iSight guide..?? Hope not, it's looong! Ps. This is a great site!
tarafından
Yes, you will have to follow the iSight guide.
tarafından
Yorum Ekle
Yanıtını ekle
Pekka Kurki sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 459
