Ana içeriğe geç
Sony tarafından Eylül 2004'te piyasaya sürülen daha küçük, daha ince ve daha sessiz Playstation 2 (SCPH-700xx) modeli.
PS2 slimline no power.
Accidentally inserted wrong power adapter into PS2 Slimline, now I have no power. Is there a fuse or some other component that I have to or can replace inside to get it working again?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 3
2 Yorum:
Most likely happened is that it powered on and soon after a capacitor or circuit got fried.
if this is true was there any smoke or the smell of something burnt?
tarafından
Hi oldturkey there was no smoke or smell, the device just simply failed to start. For this reason is why I thought that there might be a protective fuse.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
John, attached image will show you all the fuses on your logic board. Use a multimeter to check for continuity of those fuses. Pay particular interest to the resettable fuses. Of course, look for any charred, burned, or missing component as well. Hope this helps, good luck.
Resim
Bu yanıt yardımcı oldu mu?
Puan 0
4 Yorum:
Cheers for the diagram oldturkey and thanks for the help
tarafından
you are welcome, good luck.
tarafından
Stupid question, how do you reset the fuses??
tarafından
Resettable fuses should reset automatically when the power has been off for a while.
tarafından
Yorum Ekle
Yanıtını ekle
John sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 20
Son 30 gün: 106
Her zaman: 12,619
