Rear headrest will not come down
THe rear head rest in my 2000 S80 ae electrically controlled. I think the switch is blown. Can yo manually get them down? Or how do you check for the electrical problem.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Jack, check the fuses. for the headrest restraint it is fuse #7 (10amp) in the trunk fuse box. If those are okay, check the relay that controls your headrest. In the trunk area fold the left rear trim on the rear corner behind that is the relay box. Look for relay RMI14 on the attached image.
Bu yanıt yardımcı oldu mu?
will let you know after i try it.
cannot be the the fuse. one headrest locks in the up position and releases with the dash switch. other one will not lock in up position!
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 17
Her zaman: 4,712
1 Yorum
Ive installed the bench with headrests, installed the console with switch and the relays. But no luck. Should the function be activated somehow?
Martijn Jongen tarafından
