Ana içeriğe geç
1.8 veya 2 GHz G5 işlemci ve 2 GB'a kadar DDR1 sistem RAM'i
iMac G5: any chance to get this part?
i'm searching the part marked in the picture.
is there any chance to find a new one ?
the old one is dead - it gets hot after the iMac is switched on - the iMac wont start, some times it shows the red led - sometimes it switches immediately off.
after that, i startet searching on the logic board and burned my finger tip on this part
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi,
To get the part would be one problem, the bigger problem is that the solder points are under that IC. Without the proper tools there is no chance to solder the new part in place, or even desolder the old part. BTW, that an IC gets hot doesn't necessary means that the IC is damaged, maybe a different part is damaged and the IC gets hot as a result of that.
Bu yanıt yardımcı oldu mu?
Puan 3
5 Yorum:
since i repaired cell phones for years (some time at a nokia shop and the rest self employed) - i know how to change bga's - even reballing would be not the big issue - surely there can be another problem, but since there are no real "service manuals", i can only use the "trial and error" method. surely - there are some apple service manuals on the intenet, but they are useless in those cases.
tarafından
Ok, the first problem is out of the way. Could you make another photo of the IC so we can read whats written on top of it. Maybe we can find a data sheet of the IC and see why it gets hot.
tarafından
I will open the 20" later - it's 3:33 in the morning ;-)
tarafından
here it comes:
L-CP4307B
343S0319 (here comes a sign)
(copyright)2003 Apple
0534S 4917824
tarafından
well i think it's time to close this one - didn't fix the imac, the only way to get the part is from another imac...
tarafından
Yorum Ekle
Yanıtını ekle
markus weiher sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 16
Her zaman: 3,496
