Ana içeriğe geç
6.1 megapixels, ISO 200-1600, DX format, 1.5x field of view crop
Gaining access to flash components only
My flash quit working to I removed the top cover and noticed a contact that needed to be pushed in order for the flash to work, so I tested it by pressing the switch and the flash worked. Then I realized that there was a little grey bushing that was out of place enough so that it could not push the switch when opened. in the process of snapping that back into place a wire broke rendering the work to fix the flash worthless. I have read the instructions on how to take apart the D70 but it did not even mention the flash housing (possibly just the top)
So I was wondering is there a way to remove the top so I can repair the wire that was snagged without going through all the steps of tearing down the whole camera?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
michael, take a look on here and see if that will help you out.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
Thank you oldturkey03 that is what happened to mine I also used a paper clip to pull the bushing cam switch into place but was not careful enough breaking two wires. and I need to figure out how to fix the wires but they are inside where that grey bushing is
tarafından
Yorum Ekle
Yanıtını ekle
michael sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 511
