Ana içeriğe geç
''PS2'' olarak da bilinen cihaz, Sony tarafından Mart 2000'de Japonya'da ilk kez piyasaya sürülen altıncı nesil bir oyun konsoludur. Amerika Birleşik Devletleri'nde ise SCPH-30000 modeliyle 2000 yılının sonlarına doğru satışa sunulmuştur. Bu cihazın onarımı sadece standart tamir aletleri gerektirse de biraz uğraştırıcı olabilir.
Why has my screen changed to black and white
For some reason the playstation 2 is in black and white only. We tried to plug something else into the connection on the TV and it was fine but the playstation is still only black and white.
Bu iyi bir soru mu?
Puan 11
8 Yorum
i have a similar problem with my ps2, however I bought a aftermarket cable, would this cause it to show black and white?
tarafından
after playing game for sometime by pendrive graphics become un-understandable why???
tarafından
Thanks a bunch, it works!
tarafından
I have this problem, but I have the slim version, is there a difference? and I have a weird tv, that does not have the normal yellow, white and red holes for the cables, but video works, and sound just fine, but no color.
tarafından
Everytime i play f1 2006, richard burns rally, and a few other game on my ps2 my tv screen just black and white but if i play other games like gran turismo 4 original japan, and nfs underground 2 it has colours.
tarafından
3 tane daha yorum göster
Yorum Ekle
4 Cevap
Filtre ölçütü:
Seçilen Çözüm
Tara, depends on how you have your PS2 connected. If you are using the component cables, check in the system settings and check if its in regular RGB. If you use the regular Yellow, Red and White cables, it should be in RGB mode.
Bu yanıt yardımcı oldu mu?
Puan 4
9 Yorum:
this didnt help me but my PS2 is in RGB mode already
tarafından
Is ur ps2 modded
tarafından
Now it won't let me view system settings it will only play movies n is still in black and white now I can't change it back from RGB that what's it normally was
tarafından
i needed to change my tv to the AV channel instead of the component channel also to fully fix this issue
tarafından
Thank you halo117ish
tarafından
4 tane daha yorum göster
Yorum Ekle
En Yararlı Yanıt
I was having the same problem but I changed my input from component to AV and that worked.
Puan 13
15 Yorum:
I did exactly what you said and it works! Tq tq tq
tarafından
Me too!!! Thanks a bunch! Putting on AV worked :D
tarafından
Thanks a bunch, it worked!
tarafından
How can i change my input to av ?
tarafından
Just go to input it should be right on your remote for the TV and then you should see AV as one of the options then push the up or down arrow to go to the AV option the once you are on it the push select that's the button that says select on it yeah you just push that button.Thats it.
tarafından
10 tane daha yorum göster
Yorum Ekle
This one is problem on the HDTV with tons of features in it. First go to your TV's settings and open option (in my case I'm using 50" Sharp Aquos 1080p), if you don't find it check something similar to above. Then, you want to change the "Input Select" from "Component" to "Video." This will change the color system automatically as "Component" label are for newer devices and sometimes can't cope with older devices such as PS2. After you've done it you might see the "Colour System" option and that's where colour calibration option exist. My TV sets itself to NTSC 3.58 where as the component shows 480i(with monochrome color).
Puan 3
3 Yorum:
Thank you this helped a lot
tarafından
That was exactly what fixed my issue.
thank you!!
tarafından
Omg thanks so much
tarafından
Yorum Ekle
My tv is LG and it’s showing black and white for my PS2
Puan 0
2 Yorum:
@faousyjami27127 have you followed any steps in the given answers?What have you tried?
tarafından
I had the same issue. You need to use a different input on your tv.
• Check the system settings: Make sure your PS2 is in RGB mode
• Check the cables: If you're using the yellow, red, and white cables, make sure they are in RGB mode
• Check the composite cables: Make sure they are not plugged into the component input
• Check the TV inputs: Different inputs will provide different levels of image quality
• Check the HDTV's operations manual:
Look for a game mode setting or instructions to turn off digital picture enhancements
• Adjust the contrast or sharpness settings:
This may help reduce jaggies
tarafından
Yorum Ekle
Yanıtını ekle
Tara sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 53
Son 30 gün: 278
Her zaman: 269,743
