Ana içeriğe geç
Released by Nokia in May 2009, the Nokia 6303 is designed mainly for voice calls, texting, and music playback.
20 Soru Tümünü görüntüle
resetting security code how
My keypad is locked with security code. I changed the security code. Now I can't open it. Either I forgot what code I entered or I pressed the wrong numbers and I didn't know. Now I can't unlock my phone. What can I do to solve this?
Bu iyi bir soru mu?
Puan 28
4 Yorum
Tengo un telefono que me enviaron desde inglaterra y vivo en colombia como hago para el codigo de seguridad
tarafından
nokia6303 secruty code
tarafından
I keep receiving phone number. 6303036998032 ? my phone ia a Samsung ?
What is going on?
tarafından
unlock my moile nokia 6303i
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
What's your Mobile model?
Try default codes like 12345,00000.If your mobile is Nokia or Alcatel you easily reset your mobile by using Master Reset code.You can get the code from Unlock-Free.com at free of cost.Here they will generate you reset code within a minute by specifying your mobile model no and IMEI.
Note:They will provide reset codes for some basic Alcatel and Nokia mobile models only.
Bu yanıt yardımcı oldu mu?
Puan 2
3 Yorum:
Thank you you umblocked my password Im so stupid
tarafından
cant find nokia 6303ci !
tarafından
Hi security code for Nokia ta-1402 8 digits
tarafından
Yorum Ekle
Kae, follow these instructions Hope this helps, good luck.
Puan 1
3 Yorum:
Dead link. Was going to accept it, letting you know. I also got a redirect alert from AdGuard in Chrome, now the site will not load in Safari OR Chrome. Normally I'd try and find a working reference but with 2G being doomed globally I'm just going to "solve" this one by accepting @braksa's answer.
Likely blocked by the Mac AdGuard app. Not your fault the ownership changed, but I'm letting you know.
tarafından
@nick 🤣you know it does not matter as long as something worked for the OP. It’s not about accepting but about getting in solved. Best answer is always the right answer 👍
tarafından
@oldturkey03 it either redirects to a dead page or very suspicious links.
tarafından
Yorum Ekle
Yanıtını ekle
Kae sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 29
Son 30 gün: 89
Her zaman: 23,576
