Ana içeriğe geç
iPhone'un 5. jenerasyonu. Cihazın onarımı basittir; tornavidalar, kanırtma aletleri ve sabır gerektirir. GSM/CDMA / 16, 32 ya da 64 GB / Siyah ya da Beyaz.
2193 Soru Tümünü görüntüle
replaced the screen on my phone 4s and now it wont work
i just finished replacing the front screen on my 4s. I had major problems getting the battery out because the screw stripped. i ended up breaking part of the metal battery piece off of the connector. when i finished and reconnected the battery only one screw hole was still intact. i attached the battery which seems to be fully attached despite only having one screw but when i try to power on my devise nothing happens. I plugged it in and the apple symbol appeared then it went black. this happened several times before it turned on. now it is off again and i can't get it to turn on, it just goes back and forth between black and apple symbol
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
If its only the metal bit from the battery that you broke, a new battery should do it fine. If the metal battery connector is bent even 1mm, it will have trouble sitting properly, which would stop it from turning on/taking charge.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
riley sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 3
Her zaman: 920
