Ana içeriğe geç
Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
798 Soru Tümünü görüntüle
Replaced the hold switch and now click wheel is not working.
I have pulled apart my 30GB iPod video again to make sure I didn't miss anything. I have also done a restore with Itunes. The reset function works fine (holding the menu and center button until reboot). Toggling the hold switch on and off works fine as well. No response at all on any of the buttons other than the reset function. Please help!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 4
Yorum Ekle
4 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Retake it apart. Buttons may be stuck.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
The click wheel has to align in a specific way...if im not mistaken 3 little holes on the bottom of the click wheel button should help you align with ribbon cable...do you hear click sounds when pressing the button?...if not then its not align properly
Puan 2
Yorum Ekle
Check and recheck all ribbon cable connections, this is most likely where the problem is. Sometimes they appear all the way in but are not quite making contact.
Puan 1
Yorum Ekle
When openning you broke your click wheel cable or you dont have it grounded because the tail ribbon of the clickwheel came of the frame of the iPod so know you iPod will not work
I hope this helps
Puan 0
Yorum Ekle
Yanıtını ekle
gary sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 13
Her zaman: 6,557
