Ana içeriğe geç
Introduced in 1985 to bring style, performance, and luxury to a mid-sized vehicle. This model is legendary for reliability and longevity, with many still on the road decades after production ended.
2 Soru Tümünü görüntüle
How do I tighten heatshields on 1985 740 gle
how do i tighten my heat shields on my 1985 volvo 740 gle
Bu iyi bir soru mu?
Puan 1
1 Yorum
which one? there are a few on your exhaust system and your tank.
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
karmen, most of the time, either the heat shield fastener or the mounting hole has rusted out. So it depends on which heat shield "rattles" and what you will find when you have a look at it.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
En Yararlı Yanıt
I've used large hose clamps before. Works fine especially if no welder is available !
Puan 2
Yorum Ekle
Heatshields are best thought of as alarm bells. If they are loose, then (IMHO) the car sounds like it needs maintenance.
Repair the heatsheilds by re-welding the join (its a small weld that you could probably do with liquid weld that is sold over the counter).
But look over the suspension, the shocks, the steering feel, and even things like the balance on the tires (an easy check and fix)
Puan 1
Yorum Ekle
Yanıtını ekle
karmen sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 13
Her zaman: 780
