Ana içeriğe geç
Apple'ın 2012 yapımı 7,9 inçlik ilk nesil iPad mini'si; 16, 32 veya 64 GB depolama alanı ve A5 işlemciye sahiptir.
iPad Mini Wake Magnet Sensor
Nice teardown report! Finally we get to see what's inside. I'm looking for the wake magnet sensor.
I figure it should be along the right side but I can't tell from your pics.
Any ideas?
Thanks!
Bu iyi bir soru mu?
Puan 4
1 Yorum
Hi,
I would know is the wake/sleep sonsor included on the ifixit iPad mini 2 sparepart?
regards
Ralf
tarafından Paylaş
Yorum Ekle
10 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi ColinG, glad you liked the teardown!
We just took a magnet to a new iPad Mini and found the sleep sensor is about half an inch to the right of the home button on the bottom bezel:
Resim
From our teardown images, it appears to be on the digitizer cable, attached to the back of the front display here:
Resim
(This agrees with Jim Thorpe's findings in opening the smart cover—thanks, Jim!)
Bu yanıt yardımcı oldu mu?
Puan 4
Yorum Ekle
En Yararlı Yanıt
Hey y'all, i know this is an old post, but I was looking for the same answer, so after looking and looking, I figured out where the two magnets are. Hope this helps someone!!
(**Edit 7/13/13 - realized once I put mini back together that the 1st magnet was actually positioned at top of digitizer!)
Resim
Puan 8
2 Yorum:
Thank you so much for making this drawing, super helpful
tarafından Paylaş
Oh man I'm so sad...whyyyyy
tarafından Paylaş
Yorum Ekle
Looks like some of these presoldered digitizers are coming without the magnetic sensors which are located on the home button flex cable. After purchasing two of these I ended up having to harvest the OEM home button flex and moving it to the purchased digitizer. I sent a picture to the seller showing the issue. I figured I ought to put it up for your viewing as well. Note that this is showing one of the sensors near the home button. There is another sensor near the soldering joints which is a bit smaller. You can see how they work together in the youtube video above.
Thanks, Mark T.
Resim
Puan 7
Yorum Ekle
I'm looking for the same information. Seems like maybe the sleep/wake function may rely on more than one magnet. I tore apart a cover today, will be using it as a template for my own covers. Here's the magnet layout:
Resim
https://bu.mp/i9KRT3
Puan 2
3 Yorum:
Turns out, there are actually TWO magnetic triggers for sleep/wake in the iPad mini:
http://www.youtube.com/watch?v=hRO3Uaq-w...
http://www.youtube.com/watch?v=7EoPt1PA6...
tarafından Paylaş
Interesting! I tested with just a large loose magnet and got it to wake/sleep using the position I marked. We'll definitely take a closer look soon. Thanks for the update!
tarafından Paylaş
There is only one magnetic sensor. There are two magnets to hold the smart cover.
Anyways, QUESTION: Why is the sensor sensing closed, when the smart cover flap is all the way open (folded flush with the back) it still goes off? Open & closed the same thing, it will turn off. in the front that is fine because that is what it is suppose to do. Not in the back though (no homo).
Tried OEM and non-OEM home flex cables on both OEM and non-OEM digitizers. With magnets and without. All same results. WTF : )
tarafından Paylaş
Yorum Ekle
i replaced digi in my ipad mini but when i press it harder on the bottom (right side) it kinda switches off or locks. when i press it again, menu shows up. there are two magnets sticked to the digitizer. what went wrong?
Puan 1
1 Yorum:
You're shorting out buddy. Put tape along the bottom.
tarafından Paylaş
Yorum Ekle
Does anybody have better pictures of the the magnets in place at all please?
Puan 1
Yorum Ekle
Does anyone know where to get the two magnets jenny showed in her picture on the internet for a decent price? During my first iPad mini repair I forgot to remove them from the old digitizer resulting in a disabling of using the sleep wake function with magnetic covers.
Puan 1
Yorum Ekle
where can i buy the magnets .
Puan 1
Yorum Ekle
In this Video you can see the exact positon of the 2 magnets
http://www.youtube.com/watch?v=e565I-Z7-...
Puan 0
Yorum Ekle
Anyone knows why after replacing and adding the magnets to a new digitizer the Smart Cover won't work?
Puan 0
3 Yorum:
yes, it is because the smart cover lock/unlock function requires some surface mount components on the home flex that are almost always missing from aftermarket home flexes. The magnets have nothing to do with smartcover function--they just secure the cover so it doesn't flap open.
tarafından Paylaş
So does this mean I can't use the smart cover with them magnets in? I did a screen replacement added the magnets (proper ones) but the cover isnt even catching so therefore its not locking the iPad when closed.. Any ideas? Be much appreciated thanks
tarafından Paylaş
Did you test the polarity of the magnets added to the digitizer? They have to be positioned In a way they are "attracting" the ones in the smart cover.
tarafından Paylaş
Yorum Ekle
Yanıtını ekle
ColinG sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 42
Son 30 gün: 72
Her zaman: 95,174
