Ana içeriğe geç
Google-branded tablet with a 7" screen. The device needs only prying tools and screwdrivers to fix. Model number: ME370T.
Soru Kapandı
Changing of flash memory
Hi do you have any tutorial on changing the flash memory for nexus 7?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Tan Yong He, the memory is a BGA IC and soldered to the logic board. You can only change it if you have a reball setup, the right stencil and the right memory. Here is the information on the memory.
Bu yanıt yardımcı oldu mu?
Puan 1
3 Yorum:
is there anywhere that helps to change the flash memory?
tarafından
what happened that you need to change your memory?
tarafından
Can you give specific part number of Flash memory from that list?
tarafından
Yorum Ekle
The chip is the Kingston KE44B-26BN/8GB 8GB flash
However, if this chip is changed will this brick the device? I.e. is the OS stored on the (removed) flash chip, or is this flash just for user files storage?
Puan 0
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 2,767
