Ana içeriğe geç
The current line of iPod nanos comprises seven different generations.
1006 Soru Tümünü görüntüle
Soru Kapandı
Why wont the computer read my iPod nano?
every time when i connect the usb cable to the computer it wont read my iPod. i cant insert music nor take out music.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum
Are you bringing up iTunes after you attach the iPod or is it comming up on it's own after you attach the iPod?
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
The order of pluggig the iPod in should have no effect. Have you tried using another USB port if available and/or onother cable? Do you use 3rd party cable?
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Does the iPod show that it is charging when you plug it in? I would suggest verifying the dock connector on the iPod is intact (i.e. not broken, bent, etc.), if the iPod doesn't show any indication that the iPod is charging. Otherwise, Timpetou's answer is also what I would try.
Puan 0
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 3
Her zaman: 720
