Ana içeriğe geç
Release date: Jan. 24, 2008; 8MP, 3x Optical Zoom, Built in optical image stabilizer system and Face Detection software; DIGIC III Image Processor.
Get the message, Lens error, restart camera
When I turn the camera on, I get the error message, Lens error, restart camera. Then camera shuts off.
Bu iyi bir soru mu?
Puan 9
1 Yorum
I also have this problem with my Cannon 10x optical zoom.
tarafından
Yorum Ekle
5 Cevap
Filtre ölçütü:
Seçilen Çözüm
M A, this happens most often if the camera was either dropped with the lens extended, knocking it off the guides, or if exposed to dirt/debris that will bind the lens when the camera turns on. Check the space around the lens and see if the spacing is equal distance all the way around. Sometimes you can use a vacuum cleaner and apply vacuum suction on the lens while powering it on. this may remove some of the dirt/debris and free the mechanism. If none of that works, you may have to replace the lens. The guide for that is here. Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Puan 5
1 Yorum:
I even bought a can of air in a can and sprayed it all around the lens area and the whole camera, with no luck!
tarafından
Yorum Ekle
This place fixed mine: www.camerasandparts.com Service through them was wonderful - they only work on Canons though.
Puan 2
Yorum Ekle
I have a Canon Ixus 130 with the same error message, lens error. Now it won't start. I dropped it in the river. Can I use this guide to open the lens?
Puan 0
Yorum Ekle
I did the thing with the card that this guy suggested and it fixed my problem.
https://www.youtube.com/watch?v=ZaFjEGDM...
Puan 0
Yorum Ekle
In my camera it's not showing pictures and when we are taking pic.. it's not showing pictures
Puan 0
Yorum Ekle
Yanıtını ekle
M A sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 94
Son 30 gün: 233
Her zaman: 27,786
