Ana içeriğe geç
22 Kasım 2005 tarihinde piyasaya sürülen Xbox 360 kablosuz oyun kolu, Microsoft'un Xbox 360 ev oyun konsolu için kullanılan birincil oyun kontrol cihazıdır.
Central guide button has jammed
Right heres the problem, the guide button in my limited editionxbox 360 controller has jammed in place an now trys turning off the xbox every few minutes. I've not spilt anything on it, this is the only controller I've got thats suffered this problem, I've tried cleaning it with a mild alcohol cleaner which did nothing I also tried giving it a quick blast with compressed air which did nothing, is their anything I can do to fix this without soldering.
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
James Roff, take a look at this guide. Clean all components with alcohol, all rubber and plastic components with mild detergent,. Take a look at the corresponding ends and see if you can find where it jams.
Bu yanıt yardımcı oldu mu?
Puan 2
3 Yorum:
Cheers I'll give it a shot and get back to you on the results
tarafından
Had to use a fine glass paper to smooth the guide button as it was rough and stocking but apart from that your advice was spot on =) cheers
tarafından
Thank you for accepting my answer. Best of luck to you.
tarafından
Yorum Ekle
Yanıtını ekle
James Roff sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 18
Her zaman: 7,299
