Ana içeriğe geç
The Palm Pre is a multimedia smartphone that was designed and marketed by Palm with a multi-touch screen and a sliding keyboard.
I am unable to here voice in palm pre plus
When i answer any call unable to here voice when i switch it to loudspeaker i am able to here, that is my phone problem.
can any one solve the my problem ASAP.
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
surya, sounds like a blown earpiece speaker. Check this video for instructions. For further repair guides check on here. Hope this helps, good luck
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
En Yararlı Yanıt
I've run into this on my Pre+ and Pre 2 and often it's the sensor in the headphone jack not working correctly. The phone thinks a headset is still plugged in even when one isn't. This usually happens to me after I've had headphones or a cable plugged into the phone.
Short of taking the phone apart to clean or repair the piece in the headphone jack, I usually plug and unplug something into the jack until it manages to fix itself. I'll try playing music using the music player: if it's playing but you don't hear anything out of the speaker, the phone still thinks a headset is plugged in. Once the headphone sensor correctly identifies nothing plugged in, you will hear the music on the phone speaker.
Hope this helps!
Puan 2
Yorum Ekle
Yanıtını ekle
surya sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 492
