Ana içeriğe geç
Guides and support for various television (TV) brands and styles.
9054 Soru Tümünü görüntüle
Soru Kapandı
The power light flashes code: 1 flash then 2 flashes repeatedly
upon power up the power led flashes once then twice repeatedly. There is no other response. The set is a Phillips Consumer electronics, USA, mod # 37PF9431D/37. June 2006.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
John, check the power board for bulging/leaky capacitors. Not uncommon for this model. Also, check the power supply for open resistor at location 3318 see attached image. It is supposed to be a 470Ohm 5% 1W resistor. Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 292
