Nicholas Hayden , here is a copy of my answer to a very similar question "
Connect the iPod to your PC using the supplied USB cord.
Open iTunes if it did not open automatically.
Click the Options button in the lower right corner of the iTunes window.
Click Enable USB Disk Use.
Go to My Computer and select your iPod.
Select Tools and click on the folder option.
Select the View tab
Select Show hidden files and folders.
Search for the "Ipod_Control" folder aka Settings
Look in a folder that is sometimes called "Device" and find a file named "_locked".
Change the file name "_locked" to "_unlocked".
Your iPod should now function properly. Also, make sure you disable iTunes from auto syncing. The other thing, you might look at this and try it. Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Oy verildi
Geri al
Puan
İptal
Bu yoruma uygun yeri bulmak için bu konuyu kaydırın. Ardından, taşımak için "Bu yazıya yorum ekle"ye tıklayın.
