Ana içeriğe geç
The Kenmore Elite HE3 is a washing machine by Kenmore. It is identical to the Whirlpool Duet.
error code flashes h and then f.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 4
2 Yorum
i have an front load kenmore elite he3 and the cycle is stuck on handwash with the red light on and wont start how do i get it off so i cant use my washer
tarafından
What does it mean when the code H and F pop up
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
jennifer, The HF code is actually an FH code :-) FH (Water Inlet Problem--no water or insufficient water supply)
Select PAUSE/CANCEL twice to cancel the cycle. Unplug washer or disconnect power.Check the following:
open water faucets completely
check the screens at inlet hose connection to washer to make sure they are not clogged. Make sure that the water hoses are not kinked. Plug in washer or reconnect power. Re-select cycle and press START.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
It worked!!! Thank you for the advise
tarafından
Yorum Ekle
Hi, there is a few videos on YT showing how to fix these blinking codes F and H. Other than this, I have fixed my washer by cleaning the white filter (regarding codes H and F) ; first, take out the rectangular panel (lid) from bottom of your washer, there is a scrub at each side, use a star scrub driver, take out lid, place a big towel on floor under washer, rotate clockwise the filter, then you will see how dirty is! ( coins, pieces of plastic, hair, etc) clean it up, place back all. Is not difficult! You can save up to 150 bucks probably... good luck
Puan 1
1 Yorum:
Part 2 ... I forgot some details:
About the filter!.... the shape is like circle and is located on bottom side, middle. Before to take out this filter you have to recline the washer towards behind (about half feet) and place some piece of wood or brick for holding the machine while you are working on cleaning the filter... Now good luck
tarafından
Yorum Ekle
I've done this at least 5 time in the last 2 days; any other suggestions? I see & hear the water coming in…
Puan 0
1 Yorum:
check your screens ..unhook water hoses there are screens in the ends clean them and or replace them
tarafından
Yorum Ekle
Yanıtını ekle
jennifer sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 16
Her zaman: 19,632
