How do I turn washer back on when stopped during rinse cycle?
My washer got stopped during rinse cycle and now 'time remaining' is flashing and the washer won't turn back on or off. What do I do?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
First check the control locked led and see if it is on. Try using the Drain/Spin button to turn the control locked light on or off. If nothing is responding and the washer is not in control lock then most likely you have a stuck or shorted interface. You are normally able to reset this fault by pressing the pause/cancel button twice. You can then attempt to drain and spin the clothes by starting a drain/spin cycle. I would first pull the plug from the machine and let it sit for 15minuts or better and then plug it back in. this should clear it as well. Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 1,388
