it works but screen wont respond to touch
the screen works and i can see everything but it wont work when i touch the screen. and nothing is new on it has had past water damage but was long time ago.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
jedd, there a few things that can cause this. Could be a bad digitizer (most likely that it has failed). It could also be that the connector is corroded or has become dislodged, as well as a bad digitizer circuit on the logic board (least likely) I would start by replacing the digitizer. Here is the guide for it and the part is available on here as well as many other places. Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 1,198
