Ana içeriğe geç
Released April 2010 / 2.4, 2.53 GHz Core i5 or 2.66 GHz Core i7 Processors
590 Soru Tümünü görüntüle
Upgrade main logic board from 2.66 GHz to 2.8 GHz
Is it possible to replace the 15" A1286 Logic Board 2.66 GHz i7 with the 15" A1286 T9600 2.80GHz Logic Board for MacBook Pro laptop
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
If I'm understanding this correctly, you want to replace the stock logic board in your MacBook Pro 6,2 with the CTO option that adds 0.14GHz to the processor speed?
If that's what you'd like to do, then yes, it's possible to swap the logic board out with the slightly faster model -- but you have to swap the whole board. The processor itself is not upgradeable. If you have extra boards lying around, have at it. But that upgrade, otherwise, would be extremely cost prohibitive.
I wouldn't go through the trouble for an extra 0.14Ghz. It looks like the 2.66 and the 2.8 both have 512MB Nvidia 330M and 256MB of shared video memory -- so you wouldn't even see a bump in graphic performance.
All in all, it's just not worth the effort, or a lot of money to get this done.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
En Yararlı Yanıt
Thanks Josh, I have to replace the 2.66 board anyway and I have access to the 2.8 just wanted to be sure there were no other issues
I appreciate your answer and advice
Puan 1
1 Yorum:
Did it work?
tarafından
Yorum Ekle
Yanıtını ekle
d1953b sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 769
