Ana içeriğe geç
The iMac is Apple's line of all-in-one desktop computers.
8382 Soru Tümünü görüntüle
Removing suction cup marks from glass after replacement
After replacing the glass front on my imac and removing the heavy duty suction cups, I noticed a ring mark was left behind by each suction cup. Window cleaner did not remove the marks--is there a recommended way to safely remove these marks?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
Did you try with with ether or and hydro-alcoholic solution ? only a few otherwise you could make some damage on your screen....
If this answer was helpful please remember to mark it accepted.
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
Isopropyl alcohol did the trick--thanks for the suggestion!
tarafından
You're welcome. Thanks for accepting my answer...
tarafından
Yorum Ekle
Here is another option, this will work when nothing else will ! http://www.ibreakityoufixit.com/shop/cle...
Puan 0
Yorum Ekle
try the Ritec Ritepolish a mildly abrasive cream cleaner used for the romoval marks left by suction lifters on glass, mineral and other deposits.
http://www.wholesaleglasscompany.co.uk/a...
Puan 0
Yorum Ekle
Yanıtını ekle
zoomngeorge sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 13
Her zaman: 14,226
