Ana içeriğe geç
Model A1311 / Late 2009 / 3.06 or 3.33 GHz Core 2 Duo processor
Why is My Optical Drive malfunctioning?
When I start up my iMac, and when I wake it from sleep, my optical drive makes a lot of noise and tries to take in and eject a disc, two times for each action. It also doesn't recognise my attempts to insert discs.
e.g. I will try putting a disc in the drive and I can push it all the way in, put the drive does not notice, nor does it draw it in and read it. I need to put my computer into sleep mode and wake it for it to draw it in and read it.
I have tried updating my drive's firmware, yet the installer says I don't need it. I have also looked at google, and tried looking at the discussion boards, however I am unable to access them due to an error with the AppleID servers.
Is this a software problem or a hardware problem, and can i fix it?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Sound to me like a hardware problem, likely something is stuck on a disc sensor arm inside the drive.
I say pull the computer apart and take the drive out. Then open up the drive and see if anything inside looks amiss (something stuck in there, arms not moving, etc.)
Let us all know how you got on
Relevant guides:
iMac Intel 21.5" EMC 2308 Optical Drive Replacement
Technique: Optical Drive Disc Removal Technique
Optical Drive Görseli
Kılavuz
Optical Drive Disc Removal Technique, or Foreign Object Removal
Zorluk:
Kolay
1 - 10 minutes
iMac Intel 21.5" EMC 2308 Optical Drive Görseli
Kılavuz
Zorluk:
Orta
30 - 50 minutes
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Ewan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 403
