Ana içeriğe geç
The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
"Contol locked" light is on. Nothing else responds.
The "control locked" red light is on and the dryer will not respond when any other button is pushed. What to do?
Bu iyi bir soru mu?
Puan 22
19 Yorum
Thank you for the Control Lock reset fix! Worked great and saved me possibly a few hundred dollars on repairs! :)
tarafından
I have a Whirlpool Duet and I had to hold the End of Cycle button for about 3 seconds. Thanks!
tarafından
If lock light wont go off,wont reset,You Can Wash dishes! Just drive a finishing nail into lock light til it goes out. I swear you will have full wash powers, just won't lock.But, I Never knew it had a lock till it stuck. I did this,as instructed by appliance serviceman of 40yrs. It works perfectly fine and no $ outta my wallet. This is a 20 yr old washer, not saying do it on newer model Kenmore D/W.
tarafından
I tried everything else.. I literally smashed a finishing nail into the light and my piece of crap Kenmore dishwasher came to life instantly.
Totally incredible. Thanks Rusty.. Awesome advice!!
I'm tearing down my house in 4-6 months and I did not want to install a new dishwasher, so this certainly got the job done!! :-) :-) :-) :-) :-) :-) :-) :-) :-) :-)
tarafından
Worked for me. I did it with the power off and removed the finishing nail. I cannot understand how this could work. Lets see how long it lasts!!!!!!!!!!!
tarafından
14 tane daha yorum göster
Yorum Ekle
9 Cevap
Filtre ölçütü:
Seçilen Çözüm
Deborah, try this first:"
Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to lock the control panel. Listen for a double beep and observe the "Control Lock" status light is lit when the control lock is in effect. Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to unlock the control panel. The "Control Lock" status light is goes out when the control panel is unlocked.
Bu yanıt yardımcı oldu mu?
Puan 40
52 Yorum:
thank you, saved me a ton i was about to call a repair guy, and of course the machine says exactly what to do on it!!!
tarafından
OMG! Thanks! I was not looking forward o calling Sears tomorrow! You Rock!
tarafından
I tried that many times it's printed right near the button
Still won't start
tarafından
Yeap it works! Thanks
tarafından
it worked!!!! I can cancel the dryer appt!!! THANK YOU!!
tarafından
47 tane daha yorum göster
Yorum Ekle
In addition to Oldturkeys answer, try unplugging it for five minutes to allow it to reset.
Puan 5
13 Yorum:
I unplugged when all else failed still didn't work
tarafından
I'm gonna try that now
tarafından
It didn't work
tarafından
I worked in the hospital for 30 years. Anytime you call biomed with a problem that was the first thing they told you to do. Thank you!
tarafından
Tryed that too dont work...there is no control lock button
tarafından
8 tane daha yorum göster
Yorum Ekle
I have the HE4. I tried all of this, and they didn't work. However, I pressed and held the "Auto Dry Level" just to test other things, and it did the trick for me. Appreciate the input because I wouldn't have tried it otherwise though.
Puan 4
4 Yorum:
Thanks for that information..it worked! :)
tarafından
I was in the WTH portion of fixing and this worked!!
tarafından
I pressed "end cycle" and it did the trick
tarafından
I held the Auto dry level after trying the press and hold, that was great advice thank you so much
tarafından
Yorum Ekle
Turn off the power to the dryer for about a minute then turn it back on.
If the control lock is still on then push the “End of Cycle Signal” button for 3 seconds.
If it still won’t respond then you need a new control board!
Puan 4
3 Yorum:
I actually had to do as you suggested but the second time it corrected the problem. Thank you. I’m glad I did not need a new control board.
tarafından
THANK YOU - truly appreciate your help and you saved me a ton of $$$
tarafından
Thank you for the information. Occasionally the information super highway actually informs.
tarafından
Yorum Ekle
I have a Kenmore Elite he3 and I have to hold the "Drain/Spin" button "AND" the main "Start (Press & Hold)" button at the same time for 3 seconds. Works every time.
Puan 2
4 Yorum:
Seriously you just saved my life!
tarafından
Thanks!!!!!!!!!!
tarafından
I held the start button and control Lock button at the same time for for a few seconds until you hear the beep sounds and a unlock sound.
tarafından
This worked for me as well! Thank you!
tarafından
Yorum Ekle
If your control panel looks like this, I pushed and held each button for 10 seconds starting with the top left and working to my right bottom. On mine it was the ‘End of Cycle Signal” button. How I did this was, to first unplug it for 5 min (didn’t work) Then, push a single button at 1 time for 10 seconds and hit the pink cancel button 1 time between each new button. until it works or if it hadn’t , My plan was to begin pushing 2 at a time in a logical order. It won’t let me post the pictures, sorry.
Puan 2
3 Yorum:
It was the End of cycle signal button for me also. Thanks for posting.
tarafından
I also pressed the pink control button and the end of cycle button at the same time for 10 seconds and it worked.
tarafından
Holding the end of the cycle button for three seconds did the trick . Afterwards I noticed that directions printed right below the end of the cycle. Geez!
tarafından
Yorum Ekle
I held the auto steam button for 3 seconds and it worked
Puan 0
Yorum Ekle
Whirlpool duet, didn't work for me. Somtimes if I unplug, wait and replug, it goes off. Other times it does not. But I don't even think the door locks. Please help, so annoying with half dried clothes.
Puan 0
1 Yorum:
Pushing button for 3 seconds worked for me. It is time to clean the lint from the back of it. This should be done regularly. I would say at least 4 times a year.
tarafından
Yorum Ekle
Did not work for me.
Puan 0
1 Yorum:
OMG! You are a life saver! Thank you God bless you! I thought I was going to have to call a repairman!
tarafından
Yorum Ekle
Yanıtını ekle
Deborah sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 49
Son 30 gün: 181
Her zaman: 165,557
