Ana içeriğe geç
Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
Display trouble (vertical lines)
We own a 2008 20" Intel iMac (model A1224, EMC 2210).
While booting (if the iMac is cold), the display looks normal for a few seconds, then turns to a lot of thin color vertical lines.
A warm reboot immediately gives the vertical lines on the screen.
The video circuitry seems fine, since connecting an external monitor (and using video mirroring) shows the usual desktop on this external display.
Is the problem related to the inverter or the display itself ?
Many thanks in advance for the help.
J. Lejeune
Update
Thanks for the infos.
There is no current Repair Program on Apple Support for this issue.
I will try to get hand on a video cable to replace it, and see if it cures the problem.
This will be the most affordable option, I guess.
The Apple part of the LVDS cable is 922-8197 for this iMac (A1224-Early 2008-MB324LL).
Jo Lejeune
Bu iyi bir soru mu?
Puan 1
3 Yorum
Hi
I've got the same problem. So what did you do at the end it may help me.
tarafından
I've ordered the LVDS cable (Ref 922-8197 for our A1224 iMac) but received a wrong model.
I'm still waiting to receive the right one promised by the chosen Apple parts US-based reseller.
I'll keep you informed after having tested it in our faulty iMac.
tarafından
Unfortunately, replacing the LVDS cable didn't solve the issue.
We've decided to give up, the price tag for a new lcd display being unattractive...
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
This was/is a "known issue" on that age/model iMac. Go to Apple Support and enter your serial number to see if there is an extended waranty repair available. It could be the inverter, a cable (most likely) or the display (LCD) itself.
If this answer was helpful please remember to mark it accepted.''
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
Yanıtını ekle
Jo Lejeune sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 2,708
