Oil leak near timing chain
Have and oil leak near oil pan and harmonic balancer in my 2007 unlimited sahara edition wrangler
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Could be the oil pan gasket. Spray it off with some engine cleaner and investigate where it leaks from. take a couple of pictures and post those on here.There is also the oil pump that is in the front cover, driven from the front of the crankshaft. Oil passes in and out of the front cover through the timing cover gaskets which may have failed. A failed front crank seal will usually fling oil off the damper and soak the area.
Bu yanıt yardımcı oldu mu?
Oil consum engine 08 wrangler
Sergo Saintil, I suppose you mean to ask a question:-) What exactly do you want to find out about?
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 15
Her zaman: 2,014
2 Yorum
what engine is it,4.0?
oldturkey03 tarafından
3.8 v-6 engine
Miguel Guebara tarafından
