lcd display model number and replacement
i wanted to replace my lcd panel.
my macbook has lcd panel no. : lp133wx2
wanted to know if i can fit an lcd with
panel no. : lp133wx3 to my macbook.
will it still work.
thank you
Bu iyi bir soru mu?
will it still work.
thank you
Bu iyi bir soru mu?
Sagar, get the datasheets for both of the panels. The LP133WX3 is here and the LP133WX2 from here. There seems to be a minor difference with the LVDS connector, which may be negligible. The lp144wx2 uses a I-PEX 20474-030E–12 and the lp133wx3 a I-PEX 20474-030E–1# connector. The pinouts are identical.
Bu yanıt yardımcı oldu mu?
ok. thank you.
but do you think the display would work properly
Yes I do. If you read the data sheet and compare the two panels, they do appear identical.
thank you very much.
i will let you know if it worked properly after i
install the lcd this weekend.
thanks again
It worked
Thanks
That is great. Congratulations on a great fix. Thanks for accepting my answer.
Son 24 Saat: 3
Son 7 gün: 7
Son 30 gün: 22
Her zaman: 520
