Ana içeriğe geç
4 inch display / Available in a variety of colors / Released in 3 different models / 16, 32, or 64 GB capacity
331 Soru Tümünü görüntüle
Music plays only one side of the headphones?
I have tried multiple headphones, but I can only hear the music on one side of the headphones; so, the problem isn't the headphones, it is the ipod touch itself. If I plug the headphones in all the way, it only plays on one side, and if I just barely plug it in- just touch the output, then it plays on both sides. But, it has become incredibly difficult for me to listen to the songs with the headphones plugged in all the way, and its way too hard to listen to it, carefully keeping watch for the positioning of the wire. Please help me fix this problem, so that I too can completely take advantage of the Ipod Touch. It has only been a year, and this ipod has gone wrong within less than a year after purchase. Hope the description helps solve my problem.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
3 Cevap
Filtre ölçütü:
Neeru,
It sounds like the Jack or solder connection from the jack to the board is faulty. Unfortunately there is no quick solution for this issue. It will require a disassemble to diagnose accurately.
-Cheers
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
try to clean it with a few puffs of compressed air. Also, insert and remove the jack a couple of times in rapid succession. It does sound like one of the contacts is stuck and does not make contact.
Puan 0
Yorum Ekle
I had the Same problem . Get a paper clip and just pish it around for a while plug in ur headphones and it should work
Puan 0
Yorum Ekle
Yanıtını ekle
Neeru Darling sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 13
Her zaman: 7,661
