Ana içeriğe geç
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Soru Tümünü görüntüle
Soru Kapandı
"Do Not Remove" Sticker
Battery replacement went fine. Works perfectly...but what about that "Do Not Remove" sticker under connection "6". Does it serve any purpose? I destroyed it getting off to uncover the screw underneath. Is it an Apple Police sticker? Should I go back and replace it with something like a square of electrical tape?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi,
Don't worry, probably kind of warranty void. But if you change the battery you are probably not under warranty anyway!
In case you had a metallic part or other conductive material over it, you could put another piece of tape for security but it look it is the battery plastic envelope just over so no risk.
Picture from the iPhone 3GS Teardown for reference:
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 5
Her zaman: 1,031
