Ana içeriğe geç
Model A1286. Şubat 2011'de piyasaya sürüldü / 2.0, 2.2 veya 2.3 GHz Dört Çekirdekli Intel Core i7 İşlemci
How can I replace the keyboard?
Hello,
I have found a good notice to disassemble my computer
( MacBook Pro 15" Unibody Early 2011 Üst Kasa Değişimi ) and get access to the keyboard but can someone show me how to replace the keyboard please ?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 6
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
You should not have to replace the whole upper case. You can disassemble the keyboard by taking apart Logic Board & Superdrive. Disconnect the battery. Once the LB and Superdrive are out, pull out the Backlit Black layer. Underneath the black layer there is transparent layer and underneath that you will see white layer. Pull them out. Once you pull them all out, you gonna see the real Keyboard been there secured by 2 large black stews and small silver 56 screws. Large 2 screws secure the power button and the small screws secure the keyboard. Use phillips 000 screw driver and take them all out. Your keyboard will simply be out. Then replace with the new matching part and place the layer out if the new one doesn't come. Even the new one has mentioned layers, you got to separate them to while placing on the top case. It is a fun replacement. If you want a keyboard replacement video, I can send you my own raw video about it.
If you liked this idea please rate it. Thanks.
Bu yanıt yardımcı oldu mu?
Puan 15
1 Yorum:
Hi, Can you send me your raw video please... I will be grateful. Thanks
tarafından
Yorum Ekle
The keyboard is not built into the uppercase. As the top answer says, you can replace just the keyboard. There are many very small screws but it can be done.
Puan 3
Yorum Ekle
The keyboard is built into the uppercase so the whole upper case must be replaced to replace the keyboard.
Puan 1
Yorum Ekle
Yanıtını ekle
Jordan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 34
Her zaman: 4,428
