Ana içeriğe geç
1.86GHz or 2.13GHz Processor, 128GB or 256GB Flash Storage
147 Soru Tümünü görüntüle
How to power on without power button on MacBook air late 2010?
I need to know how to jumpstart logic board power-on pads using a flat screw driver. I have the manual to isolate the problem but I don´t know where to put the screw driver.
Thank you
Bu iyi bir soru mu?
Puan 3
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
Open the unit's back pane, locate the keyboard ribbon cable attached to the logic board, pin point the second pin from the left and 6th from the right and short them with a cable or crossing slim-line screwdriver. It would start up your Air.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
En Yararlı Yanıt
macpatagon, same answer as here. this is from the service manual of a MacBook Air (13-inch, Late 2010) "see if the attached image works for you (follow the red arrow:-)."
Hope this helps, good luck.
Puan 4
1 Yorum:
It's a little hard to see in this image, but they're the two smaller pads on the bottom of the cluster. This solution worked like a charm for me. Thanks
tarafından
Yorum Ekle
Hi, I have a Macbook Air 11" 2011, i found on a forum a safer way.Can't recall wich, but if you disconnect the battery cable to logic board wait a few seconds, reconnect, close your macbook back up, and then plug in your power cord it will reboot by itself. I just have to leave my macbook on all the time, but i guess it beats paying $200 for a new keyboard just because the power button went out.
Puan 2
2 Yorum:
That worked great for me -- thank you!
tarafından
A very simple and working solution, thank you !
tarafından
Yorum Ekle
Yanıtını ekle
Flavio sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 17
Son 30 gün: 25
Her zaman: 18,171
