Ana içeriğe geç
2.5 GHz dual-core Intel Core i5 processor (Turbo Boost up to 3.1 GHz) with 3 MB shared L3 cache.
263 Soru Tümünü görüntüle
Is the SSD disk the same in MacBook Pro 13" and 15"?
Hi!
Is there any differences between the SSD discs on 13" and 15"?
My 13" retina got jägermeister all over and died completely. Now I'm buying a 15" retina and I want to know if it's possible to replace the hard drive with the one in the broken 13" so that i don't loose all my valuable data.
Best regards,
Mikkel Christiansen
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
OWC makes a Envoy drive which you can put your stick in an read it via USB. They make a couple of different ones for the different sticks so check before buying. You can then transfer your data and use the old stick for storage. I think this is the one you need: http://eshop.macsales.com/item/OWC/MAU3E...
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
After reviewing the applicable teardowns, I see no reason why you couldn't swap drives. That being said, the 15" comes with twice the storage, so I'd recommend just transferring said data to your new Mac.
Cheers!
Puan 0
Yorum Ekle
Yanıtını ekle
Mikkel Christiansen sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 479
